I find my self a bit lost at the moment. I'm trying to communicate from my Vee application with an Eurotherm temperature controller. As protocol I intent to use the propriatary Bisynch via an RS232 port instead of Modbus for the ease of use (at least I hoped so). My Vee Version is 9.22. The Agilent Connection Expert is 16.1. I try to access the Instrument via a Direct I/O ASRL device.
The Bisynch RS232 communication requires RS232 to be set in this case to 19.2k Baud, 7Bit, LSB, Parity=Even, Stop Bit=1. I have configured speed, data width and so on via the Connection Expert and LSB in the advanced device options under Vee.
An example data request would look like (Hex): 04 30 30 31 31 50 56 05
The expected response would look like (Hex): 02 50 56 56 ?? ?? ?? 03 ??
If I send the request directly to the serial port via a terminal application I receive the expected response. Response time is max 10ms.
When I send the request via a Direct I/O Object (as Text or Binary) I can see the correct Hex values being send via the I/O Monitor. But I can catch no response from the serial port regardless of what I try. I always get a timeout. Somehow I must be missing some crucial part here.
With best regards, Lars Sölter
put in an interface event, with wait... if it triggers, theres bytes ready, you can take them in one at a time, and see what they use for EOL.
If the event doesnt trigger, maybe you are not sending the right EOL ? ...
And again, maybe I completely read the problem incorrectly...
