I want to write my own instrument driver for older instruments in VB.NET 4.0, for use in VEE and .NET environment.
I use a complete new installed system, Windows 7 Pro, VEE 9.2 Pro, Agilent IO Control 15.5 and VB 2010 Express with .NET Framework 4.0.
My simple lib working in the .NET environment, but I can’t load the .NET assembly into VEE.
When I register my.DLL, an error occurs “VEE can’t register the ActiceX control, please run as Administrator”: - -> I start VEE with Administrator rights!
A second error: … my.DLL is not a valid .NET assembly.
I think there is my problem. The .NET assembly is not correct build for VEE. The use of a “Strong Name” didn’t help.
I am a beginner in programming in .NET and VEE. Has anyone a simple example for me?
My goal is the use of the VEE function object browser for programming my own instrument methods and classes.
For temporarily, maybe you can change the target framework to .NET framework 3.5.
-mk
