vrf Doing continuous feedback of 1D array data
Question asked by fukui.yutaka on Sep 23, 2008
Latest reply on Sep 23, 2008 by fukui.yutaka
Hello Claudia,
thank you for your help, this variation works independent from the pc or operation system.
best regards
Thomas
Original Message
   processed by David InfoCenter
Subject:
AW: [vrf] logging time with win98 ok, but with win XP up to 99 ok, then back to zero (23-Sep-2008 9:11)
HYPERLINK "mailto:claudia.willging@kriwan-testzentrum.de"Willging, Claudia <claudia.willging@kriwan-testzentrum.de>
To:
HYPERLINK "mailto:tw@huber-online.com"tw@huber-online.com (and 1 other)
Hello Thomas,
I don`t know what problem you have exactly with your program, but you can try programming your own timer using the "now" formula. See my little example I attached.
Mit freundlichen Grüßen
i. A. Claudia Willging
Dr. Claudia Willging
KRIWAN Testzentrum GmbH & Co. KG
Teslastr. 2, D-74670 Forchtenberg
Tel.: (07947) 9150-0 (Durchwahl 9365) Fax: (07947) 9150-50
claudia.willging@KRIWAN-Testzentrum.de
Von: Thomas Walter [mailto:tw@huber-online.com]
Gesendet: Dienstag, 23. September 2008 08:33
An: VRF
Betreff: [vrf] logging time with win98 ok, but with win XP up to 99 ok, then back to zero
the program is written in hpvee version 5
best regards
Thomas
________________________
my program ran several years under win98, now we have a new pc with winXP, then the time variable run up to 99 minutes ok, then it falls back to 0 in a endless loop,
I did it with the timer function, difference of 2 inputs.
Do somebody know, how to solve this problem ??
best regards
Thomas
You are currently subscribed to vrf as: claudia.willging@kriwan-testzentrum.de
Diese E-Mail enthaelt vertrauliche und/oder rechtlich geschuetzte Informationen. Wenn Sie nicht der richtige Adressat sind oder diese E-Mail irrtuemlich erhalten haben, informieren Sie bitte sofort den Absender und loeschen Sie diese Mail. Das unerlaubte Kopieren sowie die unbefugte Weitergabe dieser Mail ist nicht gestattet.
Eingehende E-Mails mit folgenden Anhangs-Endungen werden aus sicherheitsgründen automatisch abgewiesen:
PIF, SCR, BAT, URL, EXE, COM, DLL, HTA, VBS
This e-mail may contain confidential and/or privileged information. If you are not the intended recipient (or have received this e-mail in error) please notify the sender immediately and delete this e-mail. Any unauthorized copying, disclosure or distribution of the contents in this e-mail is strictly forbidden.
Incoming E-Mails with the following attachement-extensions are automatically rejected for security reasons:
KRIWAN Testzentrum GmbH & Co. KG  -  AG Stuttgart: HRA 590480
Komplementär:
KRIWAN Verwaltungs-GmbH  -  AG Stuttgart: HRA 590645
Geschäftsführer: Dr. Ing. Elmar Zeitler, Dipl.-Ing. Jens-Peter Huischen
To: claudia.willging@kriwan-testzentrum.de
    vrf@agilent.com
You are currently subscribed to vrf as: hua_jing@agilent.com
