Hello
I imported 4 layers from Gerber files which worked without problems. For my EM simulation I now would like to place components on the imported top and bottom layer, but all components (from the Lumped-With Artwork Library) are drawn on the cond layer. How can I move these components (eg. a capacitor) to my imported top level layer? I defined a substrate with my layers and also binded the cond layer to my layers in the options->technology->layer definition menu. Am I missing something?
Thanks for a hint
Thanks for a hint
There is a Knowledge center article that shows a way to place the lumped with artwork component on a layer other than the cond layer. Search on "lumped with artwork" in the Knowledge center and you will find the article titled "Changing Insertion Layer on Lumped with Artwork Components like..."
The approach involves executing a command in the ADS command line window to define what layer to place the lumped with artwork component. Please see the article in the Knowledge center for details.
http://www.agilent.com/find/eesof-knowledgecenter
