I am getting a popup when my Agilent 16900/16800 logic analyzer software (version 03.81.0148) is launched.
It says: "Could not load an object because it is not available on this machine."
We tried re-installing the software without luck. Is it depending on an external piece of software that is not installed from the RXD software install?
After it is cleared it seems to work ok, but the popup stops our automation.
Attached is the screen shot.
1) Make sure that all of the latest patches are loaded, using Microsoft Update. Make sure you install all of the .NET packages and all dependencies.
2) Get and install the latest free FW update. It is available at www.agilent.com/find/la-sw-download. If you have any optional FW loaded, you should download and install that, as well.
3) Let us know if you still have problems.
Al
