Does anyone know how I could use a variable in an Assignment formula-object? I am trying to export data to an Excel file and currently have it set up so that the data can fill cells A5:A105, but then I get a lot of N/A's in the empty cells. If I could make the end a variable I believe that it would solve the problem.
----> I attached what I have so far (setup and fill file)
Mike
