Hi I m a new member. I m a testing technician and I use E8801A model Agilent PNA.
Can anyone please explain how to do the phase measurment and delay using this VNA in order to phase match cable assembly in a group of cable assemblies.
I briefly explains what I did.
1.Start Freq 360 MHz Stop 380 MHz
2.VNA was set to do S11,S21,S22, and S21 phase measurment.
3.Measurment: S21, Format: Phase, Marker 370 MHz
4.Did full 2 port Calibration and connect DUT (Cable).
5.Displayed SAW tooth form graph.
6.On electrical delay menu following settings were displayed
Delay =0ns
Velocity factor = 1 (actual cable has VF 0.77)
Cuttoff frequecy 450000Hz
Coax was ticked
Wave guide was unticked
7.Phase offset menu setting: 0
8. selected marker function menu and select delay.
9. A flat line was now oberserved with phase value in degrees. What will be the explanation of this value oberserved. Why it changes every time I select marker function menu and press delay tab.
9. Now electrical delay menu displayed 6.5ns.
How do I use or interpret this graph to phase match cable assemblies to each other within +/-2.5 degress.
Looking forward to anyone's reply with detailed explanation
Thanking you
Delay =0ns
Coax was ticked
Thanking you
[list=1:gyl7682g]
PNA Trace Math Operations:
http://na.tm.agilent.com/pna/help/WebHe ... ations.htm
