Hello everyone,
I am currently writing a code in 'C' using labwindows/CVI to perform a power calibration on my PNA-X N5245A. I want to calibrate the source power, using only the receiver reference. (receiver "A").
So I launch a source power cal, define the SetCalInfoEx for port 1, source 1 but when the calibration panel appears on the pna screen(very quickly), the source power field is empty. The calibration is performed and we can see the message "PASS" on the screen. But when i try applying this cal, no function is working, i tried:
-SourcePowerCalibratorApplyPowerCorrectionValues
-SourcePowerCalibratorApplyPowerCorrectionValuesEx
-ChannelSetSourcePowerCorrection
At this step I am facing two problem to finish my calibration:
First problem,I get the error althought I really apply the cal for port1 source1.
+Message: 686+
+Source power calibration has not been performed or uploaded for the specified channel and source port.+
+Severity: Error+
+EventID: E80202AE (hex)+
Second problem after one error 686, i get this error until I reboot the whole PNA althought nothing is happening on the PNA.
+Message: 685+
+Power meter is reserved by a source power cal acquisition already in progress.+
+Severity: Error+
+EventID: E80202AD (hex)+
How can I clear this 685 error without rebooting the system? How can I apply my source power calibration Correction to source 1 (maybe the problem is coming from the source power empty field during the calibration).
I have a short video of the pna screen showing the errors (It is going very fast but when watching with vlc-player in very slow motion, we can note those problems: empty source field, error message...). I can post that if it can help.
Thank you for your help, I really don't know what can I try now,
I can provide precision i needed.
Kind regards
Tigrane
+Message: 686+
+Severity: Error+
+Message: 685+
+Severity: Error+
Kind regards
Tigrane
There are two kinds of source power calibraiton and you may be calling the wrong one in the wrong order.
There is "legacy" source power calibration which operated by measuring the source power on the power meter and setting an offset array in the channel.
In newer firmware (9.33 I think) we added "guided power calibration" where the source and receviers were calibrated as part of the S-parameter guided calibration. This is saved to a calset and when the calset is applied to the channel, the source power cal data is copied from the calset to the offset array.
In general, the latter method is preferred. The former method can give some difficulties if not done in proper order.
