with version 8.5 you could disable in the "Default Preferences" the compiler warnings at the Vee development environment and at the runtime.
Now I have the version 9.2. In the development environment, you can disable the compiler warnings, but not the runtime version. This item will no longer appear in the "Default Preferences".
My application don´t work and stop if the compiler warnings are enable. How can I disable this.
Thanks
Thanks
