We have run across an issue with versions 1.91 (5.5.28.91) and 1.92 (5.5.28.95) of the N5343A D4G Exerciser firmware.
When running D4G Version 0.6 and we switch between single Rx lane and dual Rx lane, most times we am not able to get correct frames back after the switch.
Occasionally after sending the 0x41 ICLC and setting the property “AGT_DIGRF_PROP_V4_LINK_RX_LANE_CNT”, we start seeing a stream of frames, even though we only expected to see a single frame from the ICLC.
This is not an issue when running D4G Version 1.0. On version 1.7 (5.5.28.81) we do not see this issue at all.
Based on this information we are thinking it could be a possible issue with the Exerciser FW?
Any help would be appreciated. Thanks.
Al
