I found in LA sw v5.30 it is not possible to store-recall by Setup Config or Setup&Data (.ala)
an External Trigger Output setting, if "Feedthrough" mode activated - is it correct functionality ?
"Polarity" setting is has no problem of that kind. 16902B frame...
It is not convenient to go every time to Setup -> External Trigger Menu, and change it manually!
Edited by: Alx on Jun 15, 2012 10:48 AM
Edited by: Alx on Jun 15, 2012 10:49 AM
You might want to call your local Technical Call Center. It's free and they can walk through the process with you.
Al
