I have two old 6038A power supplies, each with a different problem:
#1 The power supply will not turn on at all (no fan/front panel) and will blow the "F2" 1 amp fuse when switched on.
#2 The power supply will go over-range when the voltage/current is increased. In fact the current will not increase at all, it stays at 0A.
If there are easy solutions to either problem I would love to hear them. If not what are my options for service and is it even worth it?
Thank you in advance for any help!
John
John
On page 97 is the schematic for the instrument.
#1) F2 (1 amp) typically blows because S2A/S2B (red circle) are incorrectly set for the applied ac or because a short exists in the bias circuitry (blue circle).
#2) Over Range: Applied line voltage is incorrect for the S2A/S2B settings or is frequently a control circuit problem and would likely need repair at the Service Center.
