Dear all,
I have problem about programming control through USB port,
When I change position USB for plug in that the software show error because position USB indirec !
Could you please advice about fix port from software
Best regard
badboy
Best regard
badboy
For devices that doesn't show up in connection expert, it should install or asks you to install drivers whenever you plug in the device in a different USB port. I had a device that recognize the plugged in USB port, if I plug it in another port, it stopped working and asks me to install driver. After I did, it works. So maybe this is your problem.
