1. on the right side is the window with the instruments called "instrument manager" in title.
Now i added there an TCPIP-instrument with adress TCPIP0::192.168.0.170::inst0::INSTR
When creating a direct-io then i can use it normally.
BUT when i rightclick and select "Configure Drivers" then i get as result "No interface or instrument found to send query to".
This is displayed with a blue background at the bottom of the Vee-window.
So how can i remove this yellow "?" ?
When i query in a direct-io with *IDN? then it works ... so the IP is correct.
2. The reason why i ask is that i suddenly have problems to call vee-functions to this instrument in Agilent Testexec SL.
There Testexec shows the error:
HP VEE: Remote Service, D:\%PATH%\%FILE% , on host, localhost reports error: Error: 801 Configuration error: Driver for "XXXXXX" not found
... while loading action %FUNCTION-NAME% from library D:\%PATH%\%FILE%.vee.
... during Pre/Postrun of Call to %FUNCTION-NAME%.
... during Pre/Postrun of Test %FUNCTION-NAME%.
%PATH% and %FILE% is the path/file of the vee-library where the function is saved.
XXXXXX is the name of the instrument in the instrument-manager
%FUNCTION-NAME% is the name of the function in vee.
The thing is that the actions used to work. So perhaps it will be solved when i can remove the yellow ? in vee...
3. I tested the same action and vee-library on another computer and there its working.
The only difference is that they have different vee-versions:
Not working with: 9.21.14415.0 (Dec 15, 2010)
Working: 9.2.13522.0 (Mar 22, 2010)
Also: When i select on the "Working PC" the instrument-manager + configure drivers then it comes up with "Send *IDN? to ....." There i click on OK and after this the yellow ? changes to a green icon.
So there seems something to be damaged on the not working PC or there is a problem with the last vee-update?
Thanks for any ideas
![Image]()
