YNT: vrf Closing Program that was opened using Execute Program (PC)
Question asked by VRFuser on Sep 17, 2008
Latest reply on Sep 17, 2008 by VRFuser
Thanks Cengiz, that works fine for me.
kind regards,
Intasar
Cengiz EKEN wrote:
> Hi,
> Windows has task kill feature in windows XP operating system. To kill a application, you need get the process id(PID) of the running process.
> To see the list of process with process id(PIDs), Go to a command prompt and run the command "tasklist" to see running processes with PID numbers. So, in VEE you can get the complete list into the file and search for your process and its related PID. After that you can write and execute command line using "tskill PID_No". In my case i killed my telnet application using "tskill 2200" where 2200 is the PID number of the current telnet session.
> Hope this helps
> Cengiz EKEN, Lead Design Engineer
> Aselsan A.S,Ankara
> ________________________________
> Kimden: Intasar Khan [mailto:Intasar.Khan@axisnt.com]
> Gönderilmis: Çar 17.09.2008 13:42
> Kime: VRF
> Konu: [vrf] Closing Program that was opened using Execute Program (PC)
> Hello VRF,
> Looking for some help with how to close a program using VEE that is
> opened with the Execute Program object
> I open a telnet command shell to COM1 (Putty in my example) with a
> Execute Program, after a short time the telnet command shell needs to
> be closed by VEE so a log is created (putty.log) which is then
> analysed. The tester cannot close the command shell as the programs
> needs to take logs several times. So i need some way in VEE to close
> the putty telnet command shell.
> any help or advice appreciated,
> thanks,
> Intasar
> You are currently subscribed to vrf as: ceken@mst.aselsan.com.tr To
> subscribe please send an email to: "vrf-request@lists.it.agilent.com" with the word subscribe in the message body.
> To send messages to this mailing list,  email "vrf@agilent.com".
> Search the "unofficial vrf archive" at "http://www.vrfarchive.com/vrf_archive".
> Search the Agilent vrf archive at "http://vee.engineering.agilent.com <http://vee.engineering.agilent.com/> ".
> Dikkat:
> Bu elektronik posta mesaji kisisel ve ozeldir. Eger size
> gonderilmediyse lutfen gondericiyi bilgilendirip mesaji siliniz.
> Firmamiza gelen ve giden mesajlar virus taramasindan gecirilmekte,
> guvenlik nedeni ile kontrol edilerek saklanmaktadir. Mesajdaki
> gorusler ve bakis acisi gondericiye ait olup Aselsan A.S. resmi gorusu
> olmak zorunda degildir.
> Attention:
> This e-mail message is privileged and confidential. If you are not the
> intended recipient please delete the message and notify the sender.
> E-mails to and from the company are monitored for operational reasons
> and in accordance with lawful business practices.
> Any views or opinions presented are solely those of the author and do
> not necessarily represent the views of the company.
> You are currently subscribed to vrf as: Intasar.Khan@axisnt.com To
> Search the Agilent vrf archive at "http://vee.engineering.agilent.com".
