The only FFT Span settings close enough for my test are 2 and 5 KHz so I used the Agilent Connection Expert to set the FFT span to 3KHz. I'm testing a 2.7 KHz wide I.F. bandpass filter for flatness. The Wave generator was connected to the receivers antenna and the waveform was set to generate wideband noise. The DSOX3024 was connected to the receivers audio output. Whats nice about this setup is, you don't need a spectrum analyzer with a tracking generator. I can setup a quick test to verify the filter.
Edited by: Willco788 on Jun 7, 2012 4:23 PM
Edited by: Willco788 on Jun 7, 2012 4:25 PM
