Using DIRECT I/O block in Agilent VEE 7.5 in order to acquire data of scope's (DSO81204b) channel 1 a Run Time error occured :
Configuration error GPIB Interface , at 7, is not configured for this sytem
Error number : 801
Refer to the Installation Manual for instructions
in Transaction Number 1
Object title :scope(ag54832@707)
Object type:Direct I/O
The problem ocuured after tried to connect other instruments through GPIB.
I tried to install Agilent IO Libraries SUITE 15.0
Thanks in advance for your support.
Error number : 801
Make sure the scope GPIB address is 7.
