As I know, the PNA E8362B have no serial port at its back. May I know what is the functions for other ports such as gpib talker/listener port, Aux I/O, test set port and handler I/O port ? If I want to read the data directly from the PNA, which one should I use ? I know the gpib port can be used to read the data to PC using the gpib cable. Other than the gpib port, which port I can use to read the data directly from PNA to any board wthout using any PC ? Thanks.
Dayah
Dayah
