I'm using the 41421B Source Meter Unit in voltage mode. What is the source impedance (especially reactance) ?
When I use the force and sense connections, the sense is used to correct the forcing voltage. How does this change the source impedance? What is the speed of the correction? Can this be used to correct 10 ns ripples?
Steve
Steve
Can you check on the model number? I cannot find that model number on our website.
