I'm using the intuilink v 1.1 to read the data from PNA E8362B. My problem is I can't set how many readings that I want to read from the PNA E8362B. I want to set the data will be read to txt file every 2 seconds. If I want to use VEE Pro 7.5, how is the configure command ?
I had the software for VEE Pro 7.5. Can someone provide me the solution for this ?
Thabks.
Dayah
Thabks.
Dayah
If you can run this on the PNA, you might see if the data logging macro, suits your needs.
PNA Data Logging Macro:
http://na.tm.agilent.com/pna/apps/datalogger_pkg.zip
