When i try to read instant pressure or idn or something like that from Fluke PPC-4 a problem is occured. But I want to set a new target pressure everything is fine.
Please check the picture.
Thanks in advance, best regards.
(I use VEE Pro 9.2)
(I use VEE Pro 9.2)
When your requesting a reading, should you have a question mark after the command... for example 'PR?'
Also, not sure about the bytes sending afterwards..... you should be able to delete those transactions and just on the PR? command transaction, click EOL on....
Hope it helps.
