I've encountered a problem when tried to clear the limit table in VEE using command ":CALC1:LIM:DATA 0", there was a error message “Numeric data not allowed” shown on NWA. But sometimes it worked successfully.
The NWA is E5070B with firmware revision A.06.50. As the command works sometime, so I think it shouldn't be the problem of the old firmware revision.
Can any help me on this?
Thanks a lot!
Thanks a lot!
Can you share the block of code that is sending the command? It will be easier that way.
-mk
