Hi Gary
Try "The Boat Anchor Manual Archive" http://bama.edebris.com/manuals/
Steen
_____
From: Voltz, Gary [mailto:gary.voltz@AirservicesAustralia.com]
Sent: 18. december 2007 00:58
To: VRF
Subject: [vrf] Programming Manual - Marconi 2965 Communications Test Set
To all VRFers,
I know it’s probably not a good time of year to ask, but here goes anyway.
We have two Marconi 2965’s which we calibrate each year. I’ve automated the process for their predecessor the 2955, 2955A, 2955B, and 2955R and for their successor the 2945, 2945A and more recently the 2945B, and I would now like to automate the 2965.
Does anyone have the GPIB programming Manual, or know where I can find one? I’ve got hold of a copy of the MI-BASIC manual, and the syntax is different to the GPIB.
So far I’ve worked out that “AFGEN1 LEVEL 1 V” from MI-BASIC can be changed to “AFGEN1:LEVEL 1 V” for the GPIB, so it appears as if at least early SCPI is involved. I’ve worked out a few more commands, but I’m sure there are a lot more to be had.
e.g. “TEST RX” puts it into Receiver Test Mode and “TEST TX” puts it into Transmitter Test Mode
Anyway, Seasons greetings, and thanks in advance.
Cheers,
Gary
Gary Voltz
Steen
_____
To: VRF
To all VRFers,
Cheers,
Gary
Gary Voltz
Cheers,
Gary
Gary Voltz
SASTO4
Test Equipment and Maintenance and Calibration Centre
Facilities Management Services
Technology and Asset Services
Airservices Australia
E-mail: gary.voltz@airservicesaustralia.com
_____
Ph 1300 301 120 (within Australia)
Ph +61 7 3866 3382 (outside Australia)
Fax +61 7 3866 3531
HYPERLINK "http://www.airservicesaustralia.com/"www.airservicesaustralia.com
CAUTION: This e-mail is confidential. If you are not the intended
recipient, you must not disclose or use the information contained
in it. If you have received this e-mail in error, please tell us
immediately by return e-mail and delete the document.
Airservices Australia does not represent, warrant or guarantee
that the integrity of this communication is free of errors, virus
or interference.
