Mark & Friends,
I have the 6.2 update but I've found that it fixed problems I don't care about and caused problems I do care about. As a result I only use 6.01.
This toggle difficulty has just popped up recently although the application has been in use for many years (5?) under 6.01.
Barrie
Goldberg, Mark wrote:
> Barrie,
> Have you tried downloading the patch to VEE 6.2. As I remember the
> 6.01 had several bugs that were fixed in 6.2. I don't remember what
> any of them were though.
> Mark
> -----Original Message-----
> From: bwalden [mailto:bwalden@whoi.edu]
> Sent: Wednesday, January 16, 2008 8:19 PM
> To: VRF
> Subject: [vrf] Toggle displays
> Hi Folks,
> I can't believe I'm the first to see this - I've probably missed a few
> previous messages so please bare with me. I have a Vee 6.01
> application that uses a number of Vee standard "toggle" objects. The
> application works correctly in the development environment but the vxe
> version does not display the toggle graphics (the caption is
> displayed). I've experimented with all the Vee supplied toggle
> graphics in a simple "panel display" application and none of them work except the check box.
> This problem appears to be unique to a particular computer. I'm
> running Windows XP sp2 with the usual array of security updates. A
> second XP computer with the same updates (as far as I can tell) runs
> the vxe correctly.
> Any thoughts?
> Barrie
> You are currently subscribed to vrf as: Mark.Goldberg@atk.com To
> subscribe please send an email to: "vrf-request@lists.it.agilent.com"
> with the word subscribe in the message body.
> Search the "unofficial vrf archive" at
> "http://www.vrfarchive.com/vrf_archive".
> Search the Agilent vrf archive at "http://vee.engineering.agilent.com".
> You are currently subscribed to vrf as: bwalden@whoi.edu To subscribe
> please send an email to: "vrf-request@lists.it.agilent.com" with the word subscribe in the message body.
> Search the "unofficial vrf archive" at "http://www.vrfarchive.com/vrf_archive".
Barrie
> Barrie,
> Mark
> To: VRF
> Hi Folks,
> the vxe correctly.
> Any thoughts?
> Barrie
