Hey that's perfect Martin.
trying to work out why when I did a similar thing the 'From String' threw an error if there wasn't a comma present...? - must've been doing something else wrong..
Many thanks - vrf to the rescue once again...
Alex.
(And to Bernd at Agilent, sorry our system is currently blocking html
emails so I can't see the image you embedded.. If it says the same, or is
a better solution than above then please email me directly with the
solution attached..)
Alex Barrett
Test Development Engineer
Test Development Engineering
Raytheon Systems Limited
+44 (0) 1279 407768 office
+44 (0) 1279 407620 fax
+44 (0) mobile
Alex.Barrett@raytheon.co.uk
The Pinnacles,
Harlow,
Essex CM19 5BB
<martin.papproth@
nokia.com>
To
08/02/2008 07:16 <Alex.Barrett@raytheon.co.uk>
cc
Subject
RE: [vrf] removing commas from an
array
Hi Alex,
is this what you want to achieve ?
br
Martin
Sitz der Nokia GmbH: Bochum * Amtsgericht Bochum:HRB 4112 *
Umsatzsteueridentifikationsnummer: DE 811163 495 * WEEE-Reg.-Nr. DE
51797011* Vorsitzender des Aufsichtsrates: Veli Sundbäck * Geschäftsführer:
Timo Elonen, Klaus Goll (Sprecher der Geschäftsführung), Karsten Schilly
> -----Original Message-----
> From: ext bounce-5932537-2542673@it.lists.it.agilent.com
> [mailto:bounce-5932537-2542673@it.lists.it.agilent.com]
> Sent: Freitag, 8. Februar 2008 07:51
> To: VRF
> Subject: [vrf] removing commas from an array
> Hi VRFers,
> I have a problem that seems really quite straightforward, but I just
> can't find a simple answer.. If anyone has any ideas i'd love to hear
> them.
> I've got an instrument which insists on returning it's raw trace data
> as a 1d text array. Ok fair enough you might think. However, numbers
> that are over 1000 appear 1,000..
> ...so I need to remove the comma in the elements of the array that
> contain them.. just as an example my data might appear as such......
> 0: 23
> 1: 1,023
> 2: 987
> 3: 488
> 5: 2
> 6: 2,048
> 2000: 9,321
> 2001: 589
> on and on... will need to handle any size array.
> I await the completely patronising answer from some who suggests using
> RemoveCommasFromStupidTextArray();
> Thanks all,
> Alex.
> You are currently subscribed to vrf as: martin.papproth@nokia.com To
> subscribe please send an email to:
> "vrf-request@lists.it.agilent.com" with the word subscribe in the
> message body.
> Search the "unofficial vrf archive" at
> "http://www.vrfarchive.com/vrf_archive".
> Search the Agilent vrf archive at
> "http://vee.engineering.agilent.com".
[attachment "remove_commas.vee" deleted by Alex Barrett/H9458/RAYTHEONUK]
