vrf PDF Generation
Question asked by VRFuser on Apr 8, 2008
Hi
I use NovaPDF Lite v3, I think they might be up to v5 now (http://novapdf.com/download.php).  It's also free - got it off a cd that came with a PCAuthority magazine (Australia) -
http://www.pcauthority.com.au/Find/novapdf/article-types,download,published,last-2-years.aspx/N=478+865
It also works as a virtual printer driver - sometimes the pdf files are bigger than the original word document though.
hope that helps
regards
alex
Quoting "Allan (home)" <allan.strathardo@virgin.net>:
> I use PDF995 set up as a virtual printer for many applications. If set
> as default printer any program can create a PDF document by its normal
> print procedure.
> Allan A Thomson   CEng MIMechE
> www.strathardo.com
> Mobile: +44 (0)7786 917603
>   ----- Original Message -----
>   From: Vincent Petrone
>   To: VRF
>   Sent: Tuesday, April 08, 2008 7:14 PM
>   Subject: [vrf] PDF Generation
>   Greetings,
>   Has anyone found a way to generate a PDF file using VEE?  There are
> a few freeware programs available but I am not sure how easy it would
> be to use them with VEE.  Any help, example programs or suggestions
> would be appreciated.
>   Thanks,
>   Vincent Petrone
>   Test Software Engineer
>   Kathrein Inc., Scala Division
>   Medford, OR USA
>   (541) 618-5119
>   vpetrone@kathrein.com
>   www.kathrein-scala.com
>   You are currently subscribed to vrf as: allan.strathardo@virgin.net
>   To subscribe please send an email to:
> "vrf-request@lists.it.agilent.com" with the word subscribe in the
> message body.
>   To unsubscribe send a blank email to
>   To send messages to this mailing list, email "vrf@agilent.com".
>   If you need help with the mailing list send a message to
>   "owner-vrf@it.lists.it.agilent.com".
>   Search the "unofficial vrf archive" at
> "http://www.vrfarchive.com/vrf_archive".
>   Search the Agilent vrf archive at
> "http://vee.engineering.agilent.com".
> You are currently subscribed to vrf as: awir7858@mail.usyd.edu.au To
> subscribe please send an email to: "vrf-request@lists.it.agilent.com"
> with the word subscribe in the message body.
> Search the Agilent vrf archive at "http://vee.engineering.agilent.com".
Regards
Alex
This message was sent using IMP, the Internet Messaging Program.
