vrf In: Pattern generation/analyze board
Question asked by VRFuser on Mar 18, 2008
Hi Enzo
Sorry you haven't had many replies.
I have used the ADLINK PCI 7200 series with XP on VEE 6.0 or if you want really high speed and fifo try the PCI 7300 series.
They have vee drivers and has its own on board clock, so you can hand off to it while it does the data transfer in real time. Without the dreaded windows time slice knocking a hole in your data!
I have used them on a couple of projects now and they work very well, but you do need a high spec PC to run the board reliable.
http://www.amplicon.co.uk/MandC/product/PC-Digital-PCI-3640.cfm
or high speed with on board fifo
http://www.amplicon.co.uk/MandC/product/PC-Digital-PCI-2360.cfm
Good Luck Mike
  _____
From: ebergamin@autecsafety.com [mailto:ebergamin@autecsafety.com]
Sent: 17 March 2008 14:19
To: VRF
Subject: [vrf] In: Re: Pattern generation/analyze board
Sorry, but I haven't see the publication of my message/request into Vee forum.
There's any problems?
Best regards.
_______________________________________________________________________________________________________________________________
Enzo Bergamin
R&D Dept
HYPERLINK "http://www.autecsafety.com/"AUTEC SRL
VIA POMAROLI, 65
36030 CALDOGNO (VI) ITALY
PHONE:+ 39 0444 901069
FAX:+ 39 0444 901060
----- Forwarded by Enzo Bergamin/autec on 17/03/2008 15.10 -----
Enzo Bergamin/autec
12/03/2008 11.06
To
vrf@agilent.com
cc
Subject
Re: Pattern generation/analyze boardHYPERLINK "Notes://server325.autec.it/C125653000521278/32547D7F59F9E7E38525613200556E77/67973AA60DE6F149C1257409005DF68A"Collegamento
Hello group,
I'm searching a board (PCI or USB) with memory buffer (approximately 10, 15KB) and that allows me to generate and analyze
a syncronous data pattern. I would like to comunicate with this board by VEEPro to prepare the string for the generation and
to analyze the result of acquisition.
Characteristics of the data traffic - Baud rate from 20 to 50 Kbs - duration of the package from 30 to 60ms.
Can someone help me?
Thank you all and Best Regards.
Enzo Bergamin
R&D Dept
VIA POMAROLI, 65
Autec S.r.l. is registered in Vicenza, Italy (registered number IT01850360247) with its registered office at Caldogno (VI), Via Pomaroli n.65 . The contents of this email are confidential. If you are not the intended recipient, please notify us as soon as possible: you should not copy, forward, disclose or use the contents.
Autec may monitor outgoing and incoming mail for business purposes.
Please, take note of the information concerning the handling of your personal data, in compliance with art. n. 13 d.lgs 196/03. For consulting: http://www.autecsafety.com/privacy.asp
--- You are currently subscribed to vrf as: MStrutt@tycoelectronics.com To subscribe please send an email to: "vrf-request@lists.it.agilent.com" with the word subscribe in the message body. To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". Search the "unofficial vrf archive" at "http://www.vrfarchive.com/vrf_archive". Search the Agilent vrf archive at "http://vee.engineering.agilent.com".
