Herbert, you can run the different .net Versions in parallel. You may have V1.1, V2.0, V3 and V3.5 on your system with no problem.
i think that your problem is that you do only install Vee8 on your machine- which do include .net V2.0
So just install the V1.1 version of .net , then you old samples should work.
you can choose these things in the .net assemblies....
But if you say that in the development everything works fine, and in the runtime it does not- it is a vee bug perhaps. So pplease check your installed versions of .net and Vee- check for 8.51 and runtime 8.51..
detlef
_____
Von: Herbert Baer [mailto:Herbert.Baer@premierdevices.de]
Gesendet: Montag, 11. Februar 2008 10:04
An: VRF
Betreff: [vrf] Different .NET Versions
I have a problem, when changing from VEE 7 to 8. My programs dynamical loads a lot of VEE-libraries, depending on the environment where they running. In newer modules, I use functions that only available in VEE8 like "buildRecord", so that this modules must run in VEE 8 mode. This only works, when all of the loaded libraries also changed to VEE 8 mode. In the development this works fine, but in the runtime VEE crashes. The reason is, that the libraries original written in VEE 7 use .NET version 1.xx, the others written in VEE 8 use .NET version 2.xx. Also some PCs have only VEE 8 Runtime and .NET version 2 installed.
To fix this problem I had to change the .NET version in all modules manually in a text editor.
Is there a easier way to make this change, when switching to VEE 8?
Herbert Bär
Industrial Engineering
Tel. +49 (0) 911 9411-129
Fax. +49 (0) 911 9411-261
eMail HYPERLINK "mailto:Herbert.Baer@rfmd.comPremierDevices.de"Herbert.Baer@rfmd.com
_____
RFMD Germany GmbH
Löffelholzstraße 20
D - 90441 Nürnberg
Tel. +49 (0) 911 9411-0
Fax +49 (0) 911 9411-198
http://www.rfmd.com
Geschäftsführer: Robert Alan Bruggeworth, William Aldeen Priddy Jr. und Suzanne Beroset Rudy,
Handelsregister HR B 166 43, Amtsgericht Nürnberg
You are currently subscribed to vrf as: Detlef.Baranski@pilkington.de
Der Inhalt dieser E-Mail (inkl. aller Anlagen) ist vertraulich und ausschließlich für den Adressaten bestimmt. Jede Art der Verbreitung, Nutzung oder Vervielfältigung ist untersagt. Sollten Sie diese E-Mail irrtümlich erhalten haben, informieren Sie bitte sofort den Absender und löschen die E-Mail.
Unternehmensangaben der Gesellschaften mit Sitz in Deutschland:
Pilkington Holding GmbH, Haydnstraße 19, 45884 Gelsenkirchen
Sitz: Gelsenkirchen, Amtsgericht Gelsenkirchen HRB 8997
Geschäftsführung: Dr. Clemens Miller (Vorsitz), Jochen Settelmayer, Thomas Kretschmann, Robert Hales
Vorsitzender des Aufsichtsrates: Dr. Axel Wiesener
Pilkington Deutschland AG, Haydnstraße 19, 45884 Gelsenkirchen
Sitz: Gelsenkirchen, Amtsgericht Gelsenkirchen HRB 2707
Vorstand: Dr. Clemens Miller, Jochen Settelmayer
Pilkington Automotive Deutschland GmbH, Otto-Seeling-Straße 7, 58455 Witten
Sitz: Witten, Amtsgericht Bochum HRB 8443
Geschäftsführung: Thomas Kretschmann
Vorsitzender des Aufsichtsrates: Jochen Settelmayer
Bauglasindustrie GmbH, Hüttenstraße 33, 66839 Schmelz / Saar
Sitz: Schmelz / Saar, Amtsgericht Saarbrücken HRB 52020
Geschäftsführung: Manfred Ebbers
detlef
_____
An: VRF
Herbert Bär
_____
RFMD Germany GmbH
Löffelholzstraße 20
D - 90441 Nürnberg
http://www.rfmd.com
