In VEE 8.0 or later, you have an optional "Pre 8.0 Legacy I/O" feature and this I/O is enabled when you check a check-box of the
Default Preferences -> I/O -> I/O Preferences: Pre 8.0 Legacy I/O.
In VEE 8.0 or later, you now have two GPIB Interfaces, that is GPIB and GPIB(Legacy). GPIB seems to be a VISA-based interface.
Direct I/O of GPIB has no Control Input and you can use functions
(Type:Instruments) to do the same thing. On the contrary, Direct I/O of GPIB(Legacy) has the Control Input and functions.
Use GPIB(Legacy) if you want to use the Control Input of the Direct I/O.
FUKUI Yutaka
----- Original Message -----
>To: VRF <vrf@agilent.com>
>Subject: [vrf] What happed to the DeviceName Control Input on Direct
>I/O Obje
cts????????
>From: Robert A Marquardt <ramarquardt@ra.rockwell.com>
>Date: Mon, 10 Mar 2008 17:34:31 -0500
>Hey Agilent,
>I am using VEE 8 now and found I cannot add the DeviceName control
>input pins to direct I/O objects.
>We have lots of libraries to run instruments and communications in
>which we use the same library loaded multiple times under different names.
>We just pass the DeviceName to each library so it knows which COM Port
>or which GPIB Address to send the command to.
>How in the world can we do this now ????
>HELP 8-O
>Thank You & Best Regards
>.....Rob
>Rob Marquardt
>Sr. Test Engineer
>ACIG Test Engineering
>Rockwell Automation
>1201 So. 2nd St. / W5S23 / T131
>Milwaukee, WI. 53204-2496 USA
>414-382-3098
>414-382-4820 (FAX)
>You are currently subscribed to vrf as: fukui.yutaka@jp.fujitsu.com To
>subscribe please send an email to: "vrf-request@lists.it.agilent.com"
>with
the word subscribe in the message body.
>To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".
>To send messages to this mailing list, email "vrf@agilent.com".
>If you need help with the mailing list send a message to
>"owner-vrf@it.lists.it.agilent.com".
>Search the "unofficial vrf archive" at
>"http://www.vrfarchive.com/vrf_archive
>Search the Agilent vrf archive at "http://vee.engineering.agilent.com".
FUJITSU ???(?)????[?9-432] ?????????
?????????)??·?????????? ? ?? ? (FUKUI Yutaka) INTERNET E-Mail: fukui.yutaka@jp.fujitsu.com
TEL: 044-754-2238(ext:711-5-3153) FAX: 044-754-2434(ext:711-5-3178)
FUKUI Yutaka
>I/O Obje
cts????????
>Hey Agilent,
>HELP 8-O
>.....Rob
>Rob Marquardt
>Sr. Test Engineer
>Rockwell Automation
>414-382-3098
>414-382-4820 (FAX)
>with
FUKUI Yutaka
>I/O Obje
cts????????
>Hey Agilent,
>HELP 8-O
>.....Rob
>Rob Marquardt
>Sr. Test Engineer
>Rockwell Automation
>414-382-3098
>414-382-4820 (FAX)
>with
