Thank you all for the help.
_____
From: TEOH,IVAN-TH (A-Malaysia,ex1) [mailto:ivan-th.teoh@agilent.com]
Sent: 27 March 2008 03:18
To: VRF
Subject: RE: [vrf] Converting from VBA to VEE'ish
Hi Simon,
Attach a sample program that use ActiveWorkbook.SaveAs in VEE.
More info, please refer to examplesActiveXAutomationExcelInsertData.vee.
You can access the more examples by clicking "Help -> Open Example..." at menu bar.
Hope it helps.
Best Regards,
Ivan Teoh
_____
Sent: Wednesday, March 26, 2008 9:53 PM
Subject: [vrf] Converting from VBA to VEE'ish
Hi All
I have been trying to convert this VBA to VEE
ActiveWorkbook.SaveAs Filename:= "Filename"
, FileFormat:=xlWebArchive, CreateBackup:=False
Can anyone help.
Thanks
Simon
_____
This e-mail (including any attachments) is intended only for the recipient(s) named above. It may contain confidential or privileged information and should not be read, copied or otherwise used by any other person. If you are not a named recipient, please contact the sender by telephone (+44-1454-284800) and destroy the original message. Any statement and/or opinion not related to this company's business and expressed in this message is that of the author and does not necessarily reflect those of Icera. This company does not take any responsibility for the views of the author in any matter not related to the company's objective.
_____
You are currently subscribed to vrf as: ivan-th.teoh@agilent.com
You are currently subscribed to vrf as: parfitt@icerasemi.com
_____
_____
_____
To: VRF
Hi Simon,
Hope it helps.
Best Regards,
Ivan Teoh
_____
Hi All
Can anyone help.
Thanks
Simon
_____
_____
_____
_____
