Thanks to everyone for their help!
Looks like I'll be using the Build arb waveform Detlef suggested...
Thanks to all.
Alex.
|"Strutt, | Document Marked as Unclassified | |
|Michael" | | |
|<MStrutt@| | |
|tycoelect| | |
|ronics.co| | |
| m> | | |
"Strutt, Michael"
<MStrutt@tycoelec
tronics.com> To
VRF <vrf@agilent.com>
12/03/2008 08:39 cc
Subject
Please respond to RE: [vrf] limit lines in Waveform
"Strutt, Michael" (time) charts
<MStrutt@tycoelec
tronics.com>
Hi Alex
I have done such things in the past by transforming the 12 points 1201 points.
Not knowing the shape of your mask makes it difficult to advise on how to generate the mask.
But in essence each point is expanded to 100 points so that you can use the comparator object to check for fails And the xy chart to view the data with the mask overlay. But as long as the sum of the mask shape points equals the data length then its game on!
Good Luck Mike
From: Alex.Barrett@raytheon.co.uk [mailto:Alex.Barrett@raytheon.co.uk]
Sent: 12 March 2008 07:25
To: VRF
Subject: [vrf] limit lines in Waveform (time) charts
Hi all,
Struggling a bit here, I hope someone can help....
I'm using a Waveform (Time) display object. Into this, I put my limit lines
(12 co-ord points, connected), and 1201 co-ord points of instrument data.
Now i'm used to using XY charts, so each array on the input has the same number of elements, so all I've got to do is run a 'for each' on each pair of elements and check the data's not higher than the limit line for each respective point - easy.
but problem with this is I have an unmatched number of co-ords (limit lines have 12 co-ords, and data has 1201) - so how can I check if my data is below the limits?
Any ideas anyone??
Many thanks in advance for help.
You are currently subscribed to vrf as: MStrutt@tycoelectronics.com To subscribe please send an email to: "vrf-request@lists.it.agilent.com"
with the word subscribe in the message body.
Search the "unofficial vrf archive" at
"http://www.vrfarchive.com/vrf_archive".
You are currently subscribed to vrf as: Alex.Barrett@raytheon.co.uk To subscribe please send an email to: "vrf-request@lists.it.agilent.com"
Search the "unofficial vrf archive" at "
Thanks to all.
Alex.
|Michael" | | |
|<MStrutt@| | |
|tycoelect| | |
|ronics.co| | |
| m> | | |
"Strutt, Michael"
<MStrutt@tycoelec
tronics.com> To
12/03/2008 08:39 cc
Subject
<MStrutt@tycoelec
tronics.com>
Hi Alex
Good Luck Mike
To: VRF
Hi all,
Any ideas anyone??
Hi all,
Any ideas anyone??
