Warren,
Excellent, that was it. I never knew or realized that it was a redraw that was causing the flashing.
Thanks for the help.
Mark
_____
Subject: RE: [vrf] Display Flicker
Date: Wed, 28 Nov 2007 12:43:07 +0000
To: vrf@agilent.com
Mark,
I don't get any flicker, either in the VXE or the VEE file. But I wonder if it flickers because you ping the MinValue and MaxValue pins with each update - maybe that makes VEE "redraw" the slider and so you get a flicker. In your program, you only need to ping these once.
Warren
_____
From: Mark Goldberg [mailto:modelshopcnc@hotmail.com]
Sent: 28 November 2007 01:53
To: VRF
Subject: [vrf] Display Flicker
Hi All,
Does anyone know why certain objects flicker when user functions with displays are called. In the attached example, the slider flickers when the seconds display is updated, but not every time. Why does it do it sometimes and not others? How can I get rid of it or is it even possible?
Mark
_____
Share life as it happens with the new Windows Live. HYPERLINK "http://www.windowslive.com/share.html?ocid=TXT_TAGLM_Wave2_sharelife_112007"
Share now!
You are currently subscribed to vrf as: Warren.Pickles@tycoelectronics.com
You are currently subscribed to vrf as: modelshopcnc@hotmail.com
_____
Connect and share in new ways with Windows Live. HYPERLINK "http://www.windowslive.com/connect.html?ocid=TXT_TAGLM_Wave2_newways_112007"Connect now!
Mark
_____
To: vrf@agilent.com
Mark,
Warren
_____
To: VRF
Hi All,
Mark
_____
Share now!
_____
Greg
Mark Goldberg <modelshopcnc@hotmail.com> wrote:
Hi All,
Mark
_____
Share life as it happens with the new Windows Live. HYPERLINK "http://www.windowslive.com/share.html?ocid=TXT_TAGLM_Wave2_sharelife_112007"Share now!
You are currently subscribed to vrf as: sherekhan_kl@yahoo.com
_____
Never miss a thing. HYPERLINK "http://us.rd.yahoo.com/evt=51438/*http://www.yahoo.com/r/hs"Make Yahoo your homepage. --- You are currently subscribed to vrf as: ming_meng@agilent.com To subscribe please send an email to: "vrf-request@lists.it.agilent.com" with the word subscribe in the message body. To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". Search the "unofficial vrf archive" at "http://www.vrfarchive.com/vrf_archive". Search the Agilent vrf archive at "http://vee.engineering.agilent.com".
