Mike,
Very neat solution. I can see me using that in the very near future.
Cheers,
Gary
Gary Voltz
SASTO4
Test Equipment and Maintenance and Calibration Centre
Facilities Management Services
Technology and Asset Services
Airservices Australia
E-mail: gary.voltz@airservicesaustralia.com
_____
Ph 1300 301 120 (within Australia)
Ph +61 7 3866 3382 (outside Australia)
Fax +61 7 3866 3531
HYPERLINK "http://www.airservicesaustralia.com/"www.airservicesaustralia.com
CAUTION: This e-mail is confidential. If you are not the intended
recipient, you must not disclose or use the information contained
in it. If you have received this e-mail in error, please tell us
immediately by return e-mail and delete the document.
Airservices Australia does not represent, warrant or guarantee
that the integrity of this communication is free of errors, virus
or interference.
_____
From: Michael N Asbery [mailto:michael.asbery@nrl.navy.mil]
Sent: Wednesday, 30 April 2008 10:40 PM
To: VRF
Subject: RE: [vrf] User Function Calls
Take this example one step further, in a formula box
myFunction(A,B,C) returns a record with three values val1, val2, & val3
In a formula box you have four input pins (A,B,C, & D) and two output pins (T1 and Result).
Your formula is as follows:
T1 = myFunction(A,B,C);
T1.val1 * T1.val2 + D
You place in a temporary variable T1, the results of your user function. Then use two of the output values and a third input to calculate your result.
I have been using this type of records to control instruments for many years ie
takeSpectrumAnalyzerMeasurement(CenterFreq,Span,ChannelWidth) returns a record with 601 point spectrum array, and channel power measurement amplitude.
I can then analyze the spectrum or use the power measurement, but the function only returns one record of information. Much simpler when wiring boxes together.
Mike
Michael N. Asbery (202)404-3014, DSN 754
US Naval Research Laboratory fax (202)404-7661
Code 5733.20 michael.asbery@nrl.navy.mil
4555 Overlook Ave SW
Washington DC 20375-5339
_____
From: Voltz, Gary [mailto:gary.voltz@AirservicesAustralia.com]
Sent: Tuesday, April 29, 2008 7:10 PM
To: VRF
John,
Using Variables is what I have done in the past to retrieve multiple outputs from a function. However your question has made me think of an alternative.
Normal programming methodologies suggest that a function should just do one thing. So what you can do is put all the outputs into a record and have the record as the only output. Then in the formula box the record will be the returned value. This can either be direct to the Result pin or assigned to a value for output on a pin in a multi-line formula ie. myValue = myFuntion(A,B,C); with an output pin called myValue,
Then you can unbuild the record to use the data.
Gary
_____
Sent: Wednesday, 30 April 2008 8:35 AM
To: VRF
Subject: [vrf] User Function Calls
VRF Basic Question here:
A user function may be called in a formula. The inputs to the user function are in parentheses. But if the user function returns values on output pins, how are these retrieved? Or are they not available to the formula call? If I want to call a user function with a formula, do I have to use globals to get them out?
John Kinzie
john_kinzie@appsig.com
Applied Signal Technology, Inc.
214.547.4720
Fax 214.547.4770
You are currently subscribed to vrf as: gary.voltz@airservicesaustralia.com
You are currently subscribed to vrf as: michael.asbery@nrl.navy.mil
Cheers,
Gary
Gary Voltz
SASTO4
_____
Fax +61 7 3866 3531
or interference.
_____
To: VRF
Mike
_____
To: VRF
John,
Gary
_____
To: VRF
John Kinzie
214.547.4720
Fax 214.547.4770
Does anybody knows how I can display a text in vertical position. The text length will be maybe up to 50 letters.
or can we rotate a text object 180 degrees.
Sincerely,
Maria
--- You are currently subscribed to vrf as: ming_meng@agilent.com To subscribe please send an email to: "vrf-request@lists.it.agilent.com" with the word subscribe in the message body. To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". Search the "unofficial vrf archive" at "http://www.vrfarchive.com/vrf_archive". Search the Agilent vrf archive at "http://vee.engineering.agilent.com".
