Hi VRF
I’m trying to control a power meter (Anritsu) model ML2496A.
It seems that when I’m sending a command for write to it (in the IO control), the instrument receives it.
The problem occurs when I try to read data from it, for example the pulse width or other result when each results is separate by sending write to read it
And then read it.
I see that at the port which should get the IDN of the instrument I receive the measure pulse width.
Is there someone who knows what it the problem?
Regards
Arie Fainbrun
And then read it.
Regards
Arie Fainbrun
