vrf Returning Network Drive name - All sorted now (DB/RYM)
Question asked by VRFuser on Jan 11, 2008
Hi Guys.
Thanks Shawn and Yoeri for the help.
Since the code had to run from the mapped drive I couldn't use the network name anyway and as time was tight found a quick fix for the problem.
When I get more time, I will definitely try out your methods!
Best regards
David Bielawski
Test Development Engineer
Raymarine UK Ltd
Raymarine
…world leaders in marine electronics
Tel : +44 (0)23 9269 3611 (ext 1232)
Fax : +44 (0)23 9235 1994
e-mail : HYPERLINK "mailto:david.bielawski@raymarine.com"david.bielawski@raymarine.com
Website : HYPERLINK "http://www.raymarine.comRaymarine"www.raymarine.com
Raymarine UK Limited is a company registered in England & Wales
Registered office: Robinson Way, Anchorage Park, Portsmouth, Hampshire, PO3 5TD, United Kingdom
Registered number: 4578449
This e-mail is confidential and may be used only by the intended recipient. If you have received it in error,
please contact the sender immediately. Please then delete the e-mail and do not disclose its contents.
Disclaimer : http://www.raymarine.com/emailinfo-uk/
P Please consider the environment before printing this e-mail.
