vrf FAQ: interpolations -was:limit lines in Waveform (time) charts
Question asked by VRFuser on Mar 12, 2008
Hi all,
I am measuring a VGA by setting a DAC value, and measuring RF power.
I want to reduce the number of measurements I take by using curve smoothing (non-linear interpolation).  The important thing is that the curve MUST pass through the measurement points.  This means that regression is not the answer.  I have tried ‘cubic spline’ (Matlab ‘spline’), but it does odd things at the ends.  I wondered if Bezier curves would be appropriate, and if so, has anyone got a Bezier function I could make use of?
Best Regards
David Watling
  _____
This e-mail (including any attachments) is intended only for the recipient(s) named above. It may contain confidential or privileged information and should not be read, copied or otherwise used by any other person. If you are not a named recipient, please contact the sender by telephone (+44-1454-284800) and destroy the original message. Any statement and/or opinion not related to this company's business and expressed in this message is that of the author and does not necessarily reflect those of Icera. This company does not take any responsibility for the views of the author in any matter not related to the company's objective.
  _____
