vrf Difficulty extracing alternate data values from text file
Question asked by VRFuser on Mar 18, 2008
I have some USB to Serial Converters to use as an additional COM port.
Because you can communicate with the equipment via hyperterminal (USB to Serial interface ), the interface seems to be properly installed.
1) Open your VEE program and check its Interface Properties.
   Check the address of the serial interface.
2) Open Agilent IO libraries and find RS-232 serial interface
  (COM*) available on your computer.
  Its Logical unit number must coincide with VEE program's
  If different, change the Logical unit number after clicking
  "Change Properties". You might check communication with the equipment
  using Interactive IO.
May this information help you.
FUKUI Yutaka
----- Original Message -----
>Date: Tue, 18 Mar 2008 19:43:34 -0700
>From: "Jon Logan" <jon.logan.audio@gmail.com>
>To: VRF <vrf@agilent.com>
>Subject: [vrf] USB to COM adapter and Vee?
>Hello,
>Our IT department has forced us to get newly leased computers and won't
>support the old machines.  So, all of the models we can choose from
>have zero COM ports.  We went out and got USB to serial adapters and voila:
>equipment that wants a COM port interface doesn't work.  The programs
>work well with a standard (DB-9) COM port, but the USB to serial
>adapter does not work no way, no how.  We can communicate with the
>equipment via hyperterminal (USB to Serial interface ), but Vee say's it's not
>configured.   Does Vee IO libraries require the USB to COM interface to be
>USBTMC compliant too??    Has anybody ran into the same issue?   I worry
>because it is now very difficult to get a laptop with a DB-9 COM port
>and those PCMCIA cards are a bit fragile for lab environments.  Maybe I'm
>missing something easy?   If anybody can help out with a fix, I would
>appreciate it.   I checked the archive and the seems to be an issue with USB
>equipment not being ASBTMC compliant, but I'd have thought that Windows
>and the USB to Serial driver might handle the bridge to stream COM data
>out of the USB port.
>If anybody has any info, that'd be great.
>Thanks,
>Jon
>You are currently subscribed to vrf as: fukui.yutaka@jp.fujitsu.com To
>subscribe please send an email to: "vrf-request@lists.it.agilent.com"
>with
the word subscribe in the message body.
>To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".
>To send messages to this mailing list,  email "vrf@agilent.com".
>If you need help with the mailing list send a message to
>"owner-vrf@it.lists.it.agilent.com".
>Search the "unofficial vrf archive" at
>"http://www.vrfarchive.com/vrf_archive
>Search the Agilent vrf archive at "http://vee.engineering.agilent.com".
FUJITSU ???(?)????[?9-432] ?????????
  ?????????)??·?????????? ? ??  ? (FUKUI Yutaka) INTERNET E-Mail: fukui.yutaka@jp.fujitsu.com
TEL: 044-754-2238(ext:711-5-3153)     FAX: 044-754-2434(ext:711-5-3178)
