vrf RS-232 Read Terminator
Question asked by WDrago on Sep 24, 2007
Hi Doug,
Sounds like the easiest thing to do is set your read terminator to
then read one more byte to get rid of the
that follows.
Or you could read one byte at a time into a collector until you see the
sequence, then break the loop. That's a little more code and will run a little slower too, but it will work.
Bill
From: Doug Parrish [mailto:doug.parrish@comtechpst.com]
Sent: Monday, September 24, 2007 9:33 AM
To: Drago, William @NARDAEAST; VRF
Subject: RE: [vrf] RS-232 Read Terminator
Hi Bill,
            That’s what I’ve been doing and it works well enough except in one case where my product will return a response that includes multiple “
”’ in it but the end of the response is terminated by “
”.   So my UUT response looks something like this:
Status 1 = good
Status 2 = good
………up to……Status N = good
This way the digital guys get a response which looks like this
Status 1 = good
Status 2 = good
……..up to
Status N = good (end of message)
So for now I’ve been doing multiple reads and using a junction to glue them back together again.  I though I might have been missing some detail about read terminators though.
Doug Parrish
Test Engineer
Comtech PST
105 Baylis Rd
Melville, NY 11747
631.486.4126 (Direct)
631.777.8900 x 126
HYPERLINK "mailto:doug.parrish@comtechpst.com"doug.parrish@comtechpst.com
  _____
From: William.Drago@L-3com.com [mailto:William.Drago@L-3com.com]
Sent: Monday, September 24, 2007 8:43 AM
To: VRF
Hi Doug,
That makes sense to me. The read terminator is a single char. If your 232 strings end with
, set the terminator to
, then filter out the
Bill
Sent: Monday, September 24, 2007 7:50 AM
To: VRF
Subject: [vrf] RS-232 Read Terminator
            In VEE, it seems that only a single character can be specified as a read terminator.  I would like to terminate the read on “
”.  When I go into the advanced properties of the RS-232 interface and change the read terminator to “
”, close, and then re-open the advanced properties, it only retains the “
”.  Has anyone dealt with this before?
Thanks in advance,
Doug Parrish
Test Engineer
Comtech PST
105 Baylis Rd
Melville, NY 11747
631.777.8900 x 126
  _____
From: Steen Rudberg [mailto:steen.rudberg@get2net.dk]
Sent: Saturday, September 22, 2007 2:43 PM
To: VRF
Subject: Re: [vrf] Separation of characters and numbers
Hi
Just a small clean-up....
Adding "
" in the first "From String" so that size of the array only is 2 & then the "strFromLen(str,from,len)" is not needed.
And replacing "sum(x)" + "strFromLen(str,from,len)" with a "To String".
I love Token
Steen Rudberg
----- Original Message -----
From: HYPERLINK "mailto:bill.ossmann@philips.com"Bill Ossmann
To: HYPERLINK "mailto:vrf@agilent.com"VRF
Sent: Friday, September 21, 2007 3:34 PM
This comes on the same day we have a question about reading tokens. Here's one way.
Bill Ossmann
(See attached file: NumCharSeparator.vee)
"Willging, Claudia" <HYPERLINK "mailto:claudia.willging@kriwan-testzentrum.de"claudia.willging@kriwan-testzentrum.de> wrote on 09/21/2007 04:55:34 AM:
> Hello Vrf,
> I would like to separate characters from numbers in a string.
> Example:
> "Hello 123 world 456" should turn out in "Hello world" and "123 456"
> Any ideas are appreciated!
> Mit freundlichen Grüßen
> i. A. Claudia Willging
> Dr. Claudia Willging
> KRIWAN Testzentrum GmbH & Co. KG
> Testlastr. 2, D-74670 Forchtenberg
> Tel.: (07947) 9150-0 (Durchwahl 9365) Fax: (07947) 9150-50
> claudia.willging@KRIWAN-Testzentrum.de
> www.KRIWAN-Testzentrum.de
You are currently subscribed to vrf as: doug.parrish@comtechpst.com
You are currently subscribed to vrf as: William.Drago@l-3com.com
