This is really a windows question, and to make it very clear:
Make sure that your file is coming from a folder which is open for everyone ( No "Own datas" ), no file restrictions as explained below.
AND copy it to a folder which is open for everyone ( no restrictions).
Then you do not get these "File restrictions" problems....
Same problems everywhere ;-(
detlef
Von: DUMAIS,JOHN (A-Sonoma,ex1) [mailto:john_dumais2@agilent.com]
Gesendet: Mittwoch, 28. November 2007 21:48
An: VRF
Betreff: RE: RE[2]: [vrf] Error handling / troubleshooting issue
Assuming you own the file, you can use the command:
attrib -R file.ext
to make it writeable. So, you could use an execute program object where the command is something like:
cmd /c attrib -R file.exe
Sent: Wednesday, November 28, 2007 1:13 PM
Cc: PDL-LISTS,VRF (A-Lists,unix1)
Subject: RE[2]: [vrf] Error handling / troubleshooting issue
"Walker, Richard" <Richard.Walker@Herley.Com> wrote:
> Vee Users,
> Has anyone been able to overcome the following file
> properties problem?
> When running as a restricted user (Windows XP Pro) files
> that are copied from a network file server (XP Pro) onto the local
> hard drive are set as read only and the attributes cannot be changed.
If you own the file and it is in a writeable location and not locked by being open by some process--- then about the only thing left that would prevent changes is ownership.
Make sure that you own the file if everything else checks out.
Stan
You are currently subscribed to vrf as: john_dumais2@agilent.com To subscribe please send an email to: "vrf-request@lists.it.agilent.com" with the word subscribe in the message body.
You are currently subscribed to vrf as: Detlef.Baranski@pilkington.de To subscribe please send an email to: "vrf-request@lists.it.agilent.com" with the word subscribe in the message body.
Der Inhalt dieser E-Mail (inkl. aller Anlagen) ist vertraulich und ausschließlich für den Adressaten bestimmt. Jede Art der Verbreitung, Nutzung oder Vervielfältigung ist untersagt. Sollten Sie diese E-Mail irrtümlich erhalten haben, informieren Sie bitte sofort den Absender und löschen die E-Mail.
Unternehmensangaben der Gesellschaften mit Sitz in Deutschland:
Pilkington Holding GmbH, Haydnstraße 19, 45884 Gelsenkirchen
Sitz: Gelsenkirchen, Amtsgericht Gelsenkirchen HRB 8997
Geschäftsführung: Jochen Settelmayer (Vorsitz), Dr. Clemens Miller, Thomas Kretschmann, Robert Hales Vorsitzender des Aufsichtsrates: Dr. Axel Wiesener
Pilkington Deutschland AG, Haydnstraße 19, 45884 Gelsenkirchen
Sitz: Gelsenkirchen, Amtsgericht Gelsenkirchen HRB 2707
Vorstand: Dr. Clemens Miller, Jochen Settelmayer Vorsitzender des Aufsichtsrates: Dr. Axel Wiesener
Pilkington Automotive Deutschland GmbH, Otto-Seeling-Straße 7, 58455 Witten
Sitz: Witten, Amtsgericht Bochum HRB 8443
Geschäftsführung: Thomas Kretschmann
Vorsitzender des Aufsichtsrates: Jochen Settelmayer
Bauglasindustrie GmbH, Hüttenstraße 33, 66839 Schmelz / Saar
Sitz: Schmelz / Saar, Amtsgericht Saarbrücken HRB 52020
Geschäftsführung: Manfred Ebbers
