Have been using the USB I/O 24 Mk 3 for many years. Here a link to there site http://www.elexol.com/IO_Modules/
-pete
________________________________
From: Stan Bischof (Richard S) [mailto:rsb@soco.agilent.com]
Sent: Thu 3/27/2008 1:55 PM
To: VRF
Cc: vrf@agilent.com
Subject: Re: [vrf] USB Digital IO - Which One
Paul Sylvester <paul.sylvester@philips.com> wrote:
> Hi All,
> I need about 20 digital IO lines on a USB Digital IO module.
> Can you all recommend a device? I was looking at the Eagle Technology
> 24 bit unit.
> Speed is not an issue. Ease of use with VEE is the #1 issue.
"speed" is of course relative. If kHz rates are enough then the Measurement Computing devices work pretty flawlessly with VEE and even have VEE examples ( or used to at least before they were bought ).
If you want MHz rates Accesio looks really good and seems to work fine from VEE so far ( just starting in on their devices ).
Stan
You are currently subscribed to vrf as: Peter.Thomas@med.ge.com To subscribe please send an email to: "vrf-request@lists.it.agilent.com" with the word subscribe in the message body.
Search the Agilent vrf archive at "http://vee.engineering.agilent.com <http://vee.engineering.agilent.com/> ".
-pete
To: VRF
Cc: vrf@agilent.com
> Hi All,
> 24 bit unit.
Stan
Can you all recommend a device? I was looking at the Eagle Technology 24 bit unit.
Thanks in advance!
Paul
Paul Sylvester
Test Engineer, Ultrasound
Philips Healthcare
MS360
3000 Minuteman Road
Andover, MA 01810 USA
978-659-4836
