David...The tenet example you sent worked fine with a few equipment specific tweaks. Thank you!
Many thanks to everyone for all the helpful suggestions.
Steve
Sent: Thursday, April 17, 2008 11:44 AM
To: VRF
Subject: RE: [vrf] telnet communication
Stan,
I have used Activestate Expect successfully in the past and executed the programs via VEE, howver, I received the attached that is suppose to be able to telent to a system. I was unable to Make it work for me, but the person who wrote it, says it works.
DAve
Sent: Thursday, April 17, 2008 10:10 AM
To: VRF
Cc: vrf@agilent.com
Subject: Re: [vrf] telnet communication
"Scrudato, Stephan (Stephan)" <sscrudato@alcatel-lucent.com> wrote:
> VRF,
> I am trying to communicate to equipment that requires telnet
> handshaking.
> Does anyone have any telnet communication examples?
> I can connect to the equipment using To/From Socket but I am lacking
> the handshake to set up the port.
It turns out that telnet is a very complex protocol, unlike say SMTP, so implementing it at the socket level is in principle possible but is a large amount of work. You can't just open a socket and start sending commands like you might expect.
Look for a .NET object or other external code that implements the telnet protocol.
Stan
You are currently subscribed to vrf as: david.mairs@hp.com To subscribe please send an email to: "vrf-request@lists.it.agilent.com" with the word subscribe in the message body.
Search the "unofficial vrf archive" at
"http://www.vrfarchive.com/vrf_archive".
You are currently subscribed to vrf as: sscrudato@alcatel-lucent.com To subscribe please send an email to: "vrf-request@lists.it.agilent.com"
Steve
To: VRF
Stan,
DAve
To: VRF
Cc: vrf@agilent.com
> VRF,
> handshaking.
Stan
> VRF,
> handshaking.
Stan
