vrf Select Case?
Question asked by VRFuser on Apr 17, 2008
I presume your using .Net type data from Excel, and from memory it needs to have a “.value” at the end of the cell reference to get the result of the formula.
Gary Voltz
SASTO4
Test Equipment and Maintenance and Calibration Centre
Facilities Management Services
Technology and Asset Services
Airservices Australia
E-mail: gary.voltz@airservicesaustralia.com
  _____
Ph 1300 301 120       (within Australia)
Ph +61 7 3866 3382  (outside Australia)
Fax +61 7 3866 3531
HYPERLINK "http://www.airservicesaustralia.com/"www.airservicesaustralia.com
CAUTION: This e-mail is confidential. If you are not the intended
recipient, you must not disclose or use the information contained
in it. If you have received this e-mail in error, please tell us
immediately by return e-mail and delete the document.
Airservices Australia does not represent, warrant or guarantee
that the integrity of this communication is free of errors, virus
or interference.
  _____
From: Meachen, Jacob [mailto:Jacob.Meachen@adckrone.com]
Sent: Friday, 18 April 2008 12:57 AM
To: VRF
Subject: FW: [vrf] Select Case?
Thanks
I could use the Triadic operator but it would get very long if there's a lot of cases, hence the usefulness of some sort of select case statement.
Another issue is with excel, i have an excel sheet which i need to get data from, thing is the getdata block returns the equation in the cell ("=A4*b4" for example) rather than the actual result. I would use the evaluatecellformula block but it only works on a single cell and not a range of cells.
  _____
Sent: 17 April 2008 15:16
To: VRF
Cc: VRF
Subject: Re: [vrf] Select Case?
Hi Jacob -
Can use the Triadic (sp?) operator  ->   (Test ? True clause: False clause) which can be used like  (Today == GoodDay ? Smile : Frown )
lBill
"You've got to explore the edges to see where the middle is going."  Stewart Brand
"Meachen, Jacob" <Jacob.Meachen@adckrone.com>
04/17/2008 09:29 AM
Please respond to
To
VRF <vrf@agilent.com>
cc
Subject
[vrf] Select Case?
Hi VRF
I like using formula boxes for a lot of things but I find that I want to use something like a "select case" or "switch" type of statement, is there support for this or would I have to resort to using the if/then/else box?
--- You are currently subscribed to vrf as: Jacob.Meachen@adckrone.com To subscribe please send an email to: "vrf-request@lists.it.agilent.com" with the word subscribe in the message body. To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". Search the "unofficial vrf archive" at "http://www.vrfarchive.com/vrf_archive". Search the Agilent vrf archive at "http://vee.engineering.agilent.com".
You are currently subscribed to vrf as: gary.voltz@airservicesaustralia.com
