You can use the "Microsoft ADO 3.6 object library" Active-x automation tool to connect to any ODBC link installed in the windows
controll pannel's "Data sources (ODBC)" configuration tool.
You first have to install the "MySQL ODBC 3.51 driver" and then add a "System DSN" using that driver and your connection criteria.
Best Regards,
Filip Godefroi
Test Design Engineer
Newtec CY NV
Laarstraat 5
9100 Sint Niklaas
Tel: +32 37806500
Email: HYPERLINK "mailto:FGO@newtec.eu"FGO@newtec.eu
>>> "Pickles, Warren" <Warren.Pickles@tycoelectronics.com> 7/5/2008 11:45:35 >>>
Anyone had any success talking to a MySQL database from VEE?
Newtec will be present at the following exhibitions :
CommunicAsia, 17-20 June, Singapore, Booth 6B2-01
*** e-mail confidentiality footer ***
This message and any attachments thereto are confidential. They may also
be privileged or otherwise protected by work product immunity or other
legal rules. If you have received it by mistake, please let us know by
e-mail reply and delete it from your system; you may not copy this
message or disclose its contents to anyone.
E-mail transmission cannot be guaranteed to be secure or error free as
information could be intercepted, corrupted, lost, destroyed, arrive
late or incomplete, or contain viruses. The sender therefore is in no
way liable for any errors or omissions in the content of this message,
which may arise as a result of e-mail transmission. If verification is
required, please request a hard copy.
Best Regards,
Filip Godefroi
Newtec CY NV
Laarstraat 5
9100 Sint Niklaas
Tel: +32 37806500
