On Thu, Jun 5, 2008 at 10:41 PM, Shawn Fessenden <shawn@vrfarchive.com> wrote:
> I can only make a few generalizations.
>> there are a number of things
>> that refer to C:WINNTsystem32
> This doesn't really matter. What matters is the CLSID (tagged "libid"
> by the source code). I think they only include that to help troubleshoot things.
> Otherwise you'd have to lookup the CLSID to find the filename.
>> (desc "Microsoft ActiveX Plugin")
>> (filename "C:\WINNT\system32\plugin.ocx")
> Ah, the plugin control. FHF comes up empty. MS documentation is devoid
> of info. Apparently it's a problem.
> See http://support.microsoft.com/kb/813489
>> (desc "Microsoft Agent Control 2.0")
>> (filename "C:\WINNT\msagent\agentctl.dll")
> Bizzare One of TK's favorites (hehehehehe). It does cartoons!
>> (desc "Microsoft Internet Controls")
>> (filename "C:\WINNT\system32\shdocvw.dll")
> The web browser control. This would explain your "waiting for reply"
> message.
>> (desc "Microsoft Windows Common Controls 6.0 (SP4)") (filename
>> "C:\WINNT\system32\MSCOMCTL.OCX")
> An ActiveX interface to the Common Dialogs. Open/Save, Browse, Find, etc.
>> (desc "Windows Media Player")
>> (filename "C:\WINNT\system32\wmp.dll")
> Soooo... this thing plays jams while you're testing?
> -SHAWN-
Hello!
Shawn, Ed. one quick question does come to mind here. What version of Windows was 7.5 installed on? That dratted ActiveX plugin dates to the developer thing that the Evil Empire created about the time IE5 came out for building layouts and writing scripts using VBscript and so forth.
I should know I wore out a system using it. I should say I wore out a system that was running it. That one retired when it finally started to show its age.
Gregg C Levine gregg.drwho8@gmail.com
"This signature was once found posting rude messages in English in the Moscow subway."
> message.
> -SHAWN-
Hello!
This doesn't really matter. What matters is the CLSID (tagged "libid" by the source code). I think they only include that to help troubleshoot things.
Ah, the plugin control. FHF comes up empty. MS documentation is devoid of info. Apparently it's a problem.
Bizzare
message.
-SHAWN-
