Hi Chester,
I had used ths NI's card a ong time ago.
I remember int32 is a unknown type in VEE, so you need to change this definition to short or long in the head file, and also other unknown type in VEE.
e.g. "uInt32 FindDeviceHandle" should to be "long FindDeviceHandle"
and so on
GOOD LUCK!
Br
Chunyan
Sent: Tuesday, October 30, 2007 18:29 PM
To: VRF
Subject: [vrf] Using VEE pro7.5 for NI USB-8451 Control
All,
I tried to import the compiled function (Ni845x.dll & ni845x.h)
and
saw the error message attached. Does anyone have any similiar experience
or
suggestions ? Thanks a lot !!
Please be free to contact me in case of any questions.
Best regards,
Chester Kuo
(See attached file: import library error.jpg)(See attached file:
Ni845x.dll)(See attached file: ni845x.h)
This e-mail communication is confidential and is intended only
for the individual(s) or entity named above and others who have
been specifically authorized to receive it. If you are not the
intended recipient, please do not read, copy, use or disclose
the contents of this communication to others. Please notify the
sender that you have received this e-mail in error by replying
to the e-mail. Please then delete the e-mail and any copies of
it. Thank you.
You are currently subscribed to vrf as: Chunyan.Wang@centurion.se
To subscribe please send an email to: "vrf-request@lists.it.agilent.com"
with the word subscribe in the message body.
Search the "unofficial vrf archive" at
"http://www.vrfarchive.com/vrf_archive".
and so on
GOOD LUCK!
Br
Chunyan
To: VRF
All,
and
or
Best regards,
Chester Kuo
it. Thank you.
