Ömer Akbaþ <omer.akbas@arcelik.com> wrote:
> Dear VRF,
> I need to create JPEG images from HD(consumer) video frames in AVCHD
> format or HDV video frames in m2t format(Sony uses it, compressed). I
> plan to do this in VEE. I am not experienced in image processing so I
> appreciate any kind of help or suggestions from you.
You're almost certainly not going to be doing that from within VEE, unless you want to spend a LONG time learning about signal processing and doing programming.
Rather you're going to want to control an external application via command line or ( maybe ) activeX/dotNET.
I'd suggest starting by finding a video processing toolset that can deal with what you want and also be controlled.
MATLAB has some good video capabilities- this may be possible there. Otherwise there are many choices out there.
With this in hand you can write VEE functions to control the external code to do what you want.
If you want to do more work, you may eb able to find source code for routines that you want and compile them into DLL so that you can use the functions from within VEE as compiled functions.
with luck someone here in VRF will have some good pointers.
regards
Stan
> Dear VRF,
regards
Stan
I need to create JPEG images from HD(consumer) video frames in AVCHD format or HDV video frames in m2t format(Sony uses it, compressed). I plan to do this in VEE. I am not experienced in image processing so I appreciate any kind of help or suggestions from you.
Regards
Omer Akbas
Arcelik A.S.
Istanbul, Turkey
_____________________________________________________________________________________________________________________________________________
Bu e-posta mesaji kisiye ozel olup, gizli bilgiler iceriyor olabilir. Eger bu e-posta mesaji size yanlislikla ulasmissa, icerigini hic bir sekilde kullanmayiniz ve ekli dosyalari acmayiniz. Bu durumda lutfen e-posta mesajini kullaniciya hemen geri gonderiniz ve tum kopyalarini mesaj kutunuzdan siliniz. Bu e-posta mesaji, hic bir sekilde, herhangi bir amac icin cogaltilamaz, yayinlanamaz ve para karsiligi satilamaz. Bu e-posta mesaji viruslere karsi anti-virus sistemleri tarafindan taranmistir. Ancak yollayici, bu e-posta mesajinin - virus koruma sistemleri ile kontrol ediliyor olsa bile - virus icermedigini garanti etmez ve meydana gelebilecek zararlardan dogacak hicbir sorumlulugu kabul etmez.
This message is intended solely for the use of the individual or entity to whom it is addressed , and may contain confidential information. If you are not the intended recipient of this message or you receive this mail in error, you should refrain from making any use of the contents and from opening any attachment. In that case, please notify the sender immediately and return the message to the sender, then, delete and destroy all copies. This e-mail message, can not be copied, published or sold for any reason. This e-mail message has been swept by anti-virus systems for the presence of computer viruses. In doing so, however, sender cannot warrant that virus or other forms of data corruption may not be present and do not take any responsibility in any occurrence.
