That's very cool. It might be an improvement to my linear technique. I'm going to try it on my own data to see how it looks. Thanks for posting...
_____
Sent: Wednesday, March 12, 2008 2:23 PM
To: VRF
Subject: FW: [vrf] Bezier curves - minor improvement
Minor improvement
_____
Sent: 12 March 2008 18:10
To: VRF
Subject: RE: [vrf] Bezier curves
Hi Guys,
Thank you for your input. I ended up on Wikipedia and other web pages, and making rather heavy use of one of our mathematicians (poor guy).
Here is my solution attached. Seems to work fine.
Regards
Dave Watling
_____
From: Williams, Dan [mailto:Dan.Williams@analog.com]
Sent: 12 March 2008 17:25
To: VRF
Not sure if this is along the lines of what you want but there is an Excel bit here that demonstrates how the Excel smoothing function works. I was trying to get this into a useable VEE form but got pulled off to other tasks before I finished it. Maybe close to what you are looking for.
http://www.xlrotor.com/resources/files.shtml
Look for the bit that says;
Smooth_curve_bezier_example_file.xls
Dan
_____
Sent: Wednesday, March 12, 2008 12:47 PM
To: VRF
Correct: VGA = variable gain amplifier.
Linear interpolation creates sudden changes in slope, which reduces the quality of our radio. I’m struggling to remove these discontinuities. I’m having some limited joy with Wikipedia on Bezier curves, but I still get some discontinuities.
Dave
_____
From: William.Drago@L-3com.com [mailto:William.Drago@L-3com.com]
Sent: 12 March 2008 16:05
To: David Watling; VRF
VGA? Variable gain amplifier?
I'm not sure there is any interpolation method other than linear that guarantees that the result passes through the data points.
Are you sure the curve must pass through the data points? That seems like an arbitrary requirement. So what if it doesn't as long as you meet spec?
If the above is a real requirement, then are you sure you can't use linear interpolation?
I've written a lot of software for VVA (voltage variable attenuator) characterization and use a linear interpolation to fill in the points between measurements. It works quite well. I do adjust the number of data points depending where I am in the curve.
We have one product that is controllable over a 50dB range in 0.25dB steps. I characterize it in 1dB steps in its linear range and 0.5dB steps in the non-linear regions, then linear interpolate the result into a data set that covers the whole range in 0.25dB steps. The technique saves time and yields good data.
-Bill
_____
Sent: Wednesday, March 12, 2008 5:29 AM
To: VRF
Subject: [vrf] Bezier curves
Hi all,
I am measuring a VGA by setting a DAC value, and measuring RF power.
I want to reduce the number of measurements I take by using curve smoothing (non-linear interpolation). The important thing is that the curve MUST pass through the measurement points. This means that regression is not the answer. I have tried ‘cubic spline’ (Matlab ‘spline’), but it does odd things at the ends. I wondered if Bezier curves would be appropriate, and if so, has anyone got a Bezier function I could make use of?
Best Regards
David Watling
_____
This e-mail (including any attachments) is intended only for the recipient(s) named above. It may contain confidential or privileged information and should not be read, copied or otherwise used by any other person. If you are not a named recipient, please contact the sender by telephone (+44-1454-284800) and destroy the original message. Any statement and/or opinion not related to this company's business and expressed in this message is that of the author and does not necessarily reflect those of Icera. This company does not take any responsibility for the views of the author in any matter not related to the company's objective.
_____
You are currently subscribed to vrf as: William.Drago@l-3com.com
_____
_____
You are currently subscribed to vrf as: Dan.Williams@analog.com
You are currently subscribed to vrf as: watling@icerasemi.com
_____
_____
_____
To: VRF
Minor improvement
_____
To: VRF
Hi Guys,
Regards
Dave Watling
_____
To: VRF
Dan
_____
To: VRF
Dave
_____
-Bill
_____
To: VRF
Hi all,
Best Regards
David Watling
_____
_____
_____
_____
_____
_____
