James,
I assume you are using HP 8753E or similar model.
OUTPFORM gives you pairs of values, in different units depending on the analyzer display format. If you are in logmag format then the second value of the pair will always be zero. Same for phase format. If you want real and imag pairs then you have to be in polar or smith chart display format.
Secondly, why not try FORM2 which is 32 bit real number, and in VEE use:
READ BINARY x REAL32 ARRAY:number_points, 2
Will be faster than FORM4.
Warren
_____
From: James Zhang [mailto:James.Zhang@rfsworld.com]
Sent: 31 October 2007 06:18
To: VRF
Subject: [vrf] S2P data output
Hi all,
When i use FORM4 and OUTPFORM trying to export the S2P format data, why the imaginary part of the complex data is always 0 which is not the case when save to a internal disk in the network analyzer?
Any idea on how to get exactly the same S2P data as saved in internal disk?
Thanks!
Rgs,
James
--- You are currently subscribed to vrf as: Warren.Pickles@tycoelectronics.com To subscribe please send an email to: "vrf-request@lists.it.agilent.com" with the word subscribe in the message body. To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". Search the "unofficial vrf archive" at "http://www.vrfarchive.com/vrf_archive". Search the Agilent vrf archive at "http://vee.engineering.agilent.com".
Warren
_____
To: VRF
Hi all,
Thanks!
Rgs,
James
