Forsmark, Sören <Soren.Forsmark@Stoneridge.com> wrote:
> Hello,
> I'am trying to connect to a Agilent oscilloscope DSO3062A using the
> USB interface. There is no problem doing this with "Agilent 3000
> series scope connect software" but when I try to connect to the scope
> using connection expert it can't be found. Is there anyone who could help me with this?
> The scope is detected by XP and listed in the device manager. It
> should be so easy, how can it be so hard.
> Regards
> Sören Forsmark
well- quick perusal at agilent.com finds:
"SCPI programming is not available using the USB port."
A very blunt statement that
would seem to imply that while USB is there it is not the USBTMC standard required by the IO Libraries.
The SCPI interpreter appears to be limited to RS232 and GPIB in that instrument.
If my interpretation is in error, I expect someone will chime in.
If you have the scope's GPIB option that may be your best bet.
Stan
> Hello,
> Regards
> Sören Forsmark
Stan
I'am trying to connect to a Agilent oscilloscope DSO3062A using the USB interface. There is no problem doing this with "Agilent 3000 series scope connect software" but when I try to connect to the scope using connection expert it can't be found. Is there anyone who could help me with this?
The scope is detected by XP and listed in the device manager. It should be so easy, how can it be so hard.
Regards
Sören Forsmark
