vrf macro from Vee to Excel?
Question asked by VRFuser on Feb 28, 2008
Jon,
I realise you’ve already found the examples, but I would have created the Macro in an Excel Workbook and then saved it as a Template (.xlt).  The advantage of this is that the Macro resides in the Template, and when you open the Template, it doesn’t allow the original to be overwritten.  Therefore it should reduce the overheads, by simply opening the Template from VEE.
Cheers,
Gary
  _____
Sent: Friday, 29 February 2008 1:48 AM
To: VRF
Subject: [vrf] macro from Vee to Excel?
I was wodering if it is possible to 'push' a macro from Vee to excel?  I need to do this because the excel file I am writing to gets deleted every time, so when it is opened as a new file it is not associated with any macro.  I've checked the VRF archive.  I saw some cool stuff but not what I need.   I can do what I want a different way, but it would be nice to write the macro in Vee, load it into whatever workbook, then run it.
If any body has done this, I would sure appreciate a hint.
Thank you, very much,
Jon
--- You are currently subscribed to vrf as: gary.voltz@airservicesaustralia.com To subscribe please send an email to: "vrf-request@lists.it.agilent.com" with the word subscribe in the message body. To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". Search the "unofficial vrf archive" at "http://www.vrfarchive.com/vrf_archive". Search the Agilent vrf archive at "http://vee.engineering.agilent.com".
